Order Ford NAA Parts Online
1953 Ford Golden Jubilee - Hydralic Fluid
shafferdonald
10-02-2004 09:35:26
Need to know where to put the Hydralic fluid and what type to use. There are 2 plugs one on the rear and one at the transmission. Do you the same or different types.
E. Ray
10-03-2004 06:21:13
 Re: 1953 Ford Golden Jubilee - Hydralic Fluid in reply to shafferdonald, 10-02-2004 09:35:26
The fill cap for the hyd. oil is under the seat on the left side (sitting on tractor) and is at and angle
WayneNC
10-02-2004 11:56:07
shafferdonald, there are 3 top plugs,trans,rear end and hydraulic fluid where you fill from. There is a side plug on trans and rear end you remove to fill to this level. Hydraulic you add 2 gallons. There are 3 drain plugs under the tractor.I use 134D in all compartments.It takes app.2 gal.in rear and 6 quarts in trans. Wayne
shafferdonald
10-04-2004 11:56:25
 Re: 1953 Ford Golden Jubilee - Hydralic Fluid in reply to WayneNC, 10-02-2004 11:56:07
Thank you Wayne & E. Ray for your help.
