Order Ford 4000 Parts Online
1970 ford 4000 industrial
Michael J. Rohl
03-25-2008 18:22:49
can any body tell me if these were hard starting.have to either it every time.
Michael J. Rohloff
03-26-2008 19:09:19
 Re: 1970 ford 4000 industrial in reply to Michael J. Rohloff, 03-25-2008 18:22:49
thanks men, i did some checking tonight wouldnt start again i took my hand and put it over the exhaust cranked it over and felt suction. if my mechanix skills are still intact i dont think this is good. maybe i should get rid of it.im a wanna be farmer stuck in nj with 3/4 acre and some old junk that everybody tells me im nuts for trying to fix.well thanks again, if i can figure out how to put pictures on here ill show you my iron
RodInNS
03-26-2008 14:07:06
If it's tight it should start down to probably -5 C without ether or any other type of pre-heater. The thermostart should get it going down to -15 to -20 C without a block heater. Ether below that or a good block heater...
I'd also check to make sure that the starting system and battery are up to snuff. If the tractor doesn't turn over at 200 rpm then it'll wind a long time before it starts. Those were not 'great' starting engines but they were by no means poor either.
I sometimes use a sniff of ether on our 4000 when it's below freezing but that tractor doesn't have a thermostart unit. A little touch of ether is better than running the battery down. It's also a 7000 hour engine that's seen a lot of cold starts like that so the compression is not what it once was...
Rod
soundguy
03-26-2008 10:40:36
Ditto what the others say.. either addicted tractors are just in the waiting line for the engine to be rebuilt.
soundguy
awhtx
03-25-2008 19:55:08
Having to use ether to get it started regardless of temperature is a sign of a worn out (low compression) engine.
Chris in SK
03-25-2008 18:35:23
If the temperature is above freezing and you have a good battery you shouldn't need ether. Chris
