Order Ford 860 Parts Online
860 wiring help for dummies
Bob Johnston
09-30-2007 17:24:39
Once again I find myself needing help with my tractor. After changing out the head gasket, intake/exhaust manifold and wiring (all of the wiring harness, points, condensor, rotor, cap, plug wires and coil) my tractor will turn over but not fire. My question is how do I trouble shoot the wiring and what is normal. With the key on and using a volt meter I have 12 volts to one side of the coil when I ground the meter to the battery ground and check the coil and nothing on the other side (going to the distributor). Do I need to be cranking the engine over to see any voltage there? I would like to check the wiring going to the distributor with the volt meter as opposed to just replacing parts one at a time. Any help would be appreciated.
john in la
10-01-2007 05:35:27
 Re: 860 wiring help for dummies in reply to Bob Johnston, 09-30-2007 17:24:39
If you are reading 0 on the points side of the coil your power is getting to ground. This could be a short some where or something as simple as you did not make sure the points are open before doing the test.
Bob Johnston
10-01-2007 07:40:08
 Re: 860 wiring help for dummies in reply to john in la, 10-01-2007 05:35:27
John, assuming the points are open, and the way this project has been going that is probably a bad assumption, I take it that I should be reading 12 volts on the distributor side of the coil also, correct? If they are open and I am still reading "0" can I assume as "Old" suggested the most likely place to look for the problem is a short in the distributor connection, i.e., the insolator shielding the "T" bolt (connecting the coil wire to the points) from the distributor housing? Thanks and by the way the wiring drawing you sent and the spec for the diode really helped that part of the project. Thanks again
john in la
10-01-2007 18:04:12
 Re: 860 wiring help for dummies in reply to Bob Johnston, 10-01-2007 07:40:08
You are correct in your assuptions.
Test 1... Remove the point wire from the coil and check voltage at the coil. If still 0 your coil is bad; if it goes up go to test 2.
Test 2 Put the wire back on the coil and remove it from the points. If it is 0 the T bolt is bad or the wire has a short.
If the voltage goes up in test 2 replace the points and condensor because your short is in the distribtor.
soundguy
10-01-2007 07:50:32
Yep.. either points are shorted.. or the feedthru wire is shorted.
Real remote possibility that the coil primary opened.. etc.
Soundguy
steve n carol
09-30-2007 17:45:37
Bob, I don't remember what your working on, please post tractor model, Ask for a wiring diagram or search for a wiring diagram in this forum...sl
Bob Johnston
09-30-2007 19:01:46
 Re: 860 wiring help for dummies in reply to steve n carol, 09-30-2007 17:45:37
My tractor is a Ford 860 (1956) which has been converted to a 12 volt system.
old
09-30-2007 19:54:08
 Re: 860 wiring help for dummies in reply to Bob Johnston, 09-30-2007 19:01:46
Sounds like you might have a short inside the distubutor or the insalator on the side of it has gone bad. I would recheck your points etc and make sure you didn't short something out when you install them. BTDT and it can happen
