Order Ford 860 Parts Online
860 sylinders
Bob Johnston
09-17-2007 11:21:05
Well after reviewing all the help and getting the parts I replaced the head gasket on my 860 and much like the folks thought it was blown between the #2 &3 cylinders. However, I also found the number 1 and 2 cylinder full of a brownish fluid (oil and coolant?). Is this normal to find when you blow a head gasket or is there something else going on that I now need to worry about. Thanks again on my initial problem and hope this latest discovery was "fixed" with the head gasket replacement.
old
09-17-2007 12:03:12
 Re: 860 sylinders in reply to Bob Johnston, 09-17-2007 11:21:05
The stuff you found in the cylinders is probably normal because when you pull a head you can't get all the water and oil or of the passage ways and some ends up in the cylinders no matter what.
