Order Ford 860 Parts Online
860 hood
TJAllen
09-10-2007 10:06:57
Anyone know where I can get a hood for an 860?
Tim
Lumpy
09-12-2007 10:18:52
 Re: 860 hood in reply to TJAllen, 09-10-2007 10:06:57
TJ, email me! I'll send you some photos of the gas door I have. Thanks.
GlenIdaho
09-10-2007 17:34:18
TJ; Check Wengers, they have one for $73.00 and are close to you.
TJAllen
09-10-2007 17:30:15
If I knew for sure that hood assembly would fit an 860 I'd bid on it. Even though I only need the foldout part where you put gas in it.
Tim
H. Cooper
09-10-2007 17:42:42
 Re: 860 hood in reply to TJAllen, 09-10-2007 17:30:15
I have the top of the hood that you need. It is off of a 600 series with the hinges. It needs painting but otherwise is in good condition. I will take $100.00 for it plus shipping if you are interested. ( I live in S.C.)
TJAllen
09-10-2007 17:15:18
I'm live in Northern NY
Jim.UT
09-10-2007 12:53:07
I have this one for sale on ebay. It's off a Jubilee, but should work on an 860. If not, hopefully someone here will correct me.
Link to more photos of hood
Dean
09-10-2007 15:04:51
 Re: 860 hood in reply to Jim.UT, 09-10-2007 12:53:07
Jim:
The hood is higher on the 8xx series than on the 6xx series and NAA tractors but I do not know if the doglegs are taller or the mounting holes are higher.
Dean
Feron
09-10-2007 18:02:51
 Re: 860 hood in reply to Dean, 09-10-2007 15:04:51
No the hoods on a Jubilee,600 and 800 series are all the same. The Jubilee and 600 look shorter because they use the lower mounting holes.
Lumpy
09-10-2007 10:12:16
Where are you located?
