850 sos
cdv
09-07-2007 17:46:23
Got my 1st sos a 850 run good But the pto keeps running and it takes off kind of on the slow side for me,But my 1st so is it to act that way, never worked on one but looks fun,so can sunone point me the right way thanks cdv
Larry NCKS
09-08-2007 10:39:52
 Re: 850 sos in reply to Octave, 09-07-2007 17:46:23
No fix for the PTO. Maybe a good oil change and band adjustment is in order for the other.
cdv
09-08-2007 20:18:18
 Re: 850 sos in reply to Larry NCKS, 09-08-2007 10:39:52
thanks Larry when I get the book I will get in to the bands thanks cdv
cdv
09-08-2007 08:25:32
 Re: 850 sos in reply to cdv, 09-07-2007 17:46:23
slow start in all gears I think,plus i don't like the pto running the time is there a fix for that thanks cdv
Larry NCKS
09-08-2007 05:02:46
cdv said: and I think the trans takes off slow
I guess we need to know what you mean by this. Does it hestitate in all gears when you let out the inching pedal? Or are you starting out in 1st gear and think that's slow?
cdv
09-08-2007 04:55:48
871 your right,looking to get a good book and I think the trans takes off slow and you say the pto works that way ,looking to learn about sos thanks cdv
Larry NCKS
09-07-2007 21:04:13
 Re: 850 sos in reply to Larry T, 09-07-2007 17:46:23
Ditto on what Awhtx said. 850 was an older model and was a 5 speed gear transmission. Think he's got it pegged for you. Not sure what you mean by it takes off slow. Are you talking about the transmission or the PTO?
awhtx
09-07-2007 18:35:52
If it has an SOS it's NOT an 850- it's an 871 or 881. It is common for the PTO to continue turning even when OFF. You need to get the Ford Service Manual if you are going to own and operate an SOS tractor.
