Short story portion: On the PTO shaft, are the inner splines that meet up with the bearing that engages and disengages, suppose to be 100% straight.My shaft is straight its self, but the splines are straigth for around 2 1/2 inches, then all of then curve over to the left a bit, and continue to go down sort of at a slant then... sort of like [ [ / but not that surveire. Long story portion: I've been having a problem engaging and disengaging while the PTO is tightened in the shaft. At first i thought it was rusted... (tractor set for 20 years, fixed engine, on to PTO) When i pulled out the shaft, the level that engages it worked and slid back in. When i put the shaft back in it worked engaging and disengaging, until it was fully in, then it wouldn't move back and forth. I figured it was that the part inside wasn't sliding freely on the end of the shaft, and it looks like the splines on the shaft arn't completely straight. Is this the problem? IS this common to happen to the PTO if not engaged properly with the clutch?
