Order Ford 860 Parts Online
860 side cover gasket
Tim12138
05-25-2007 18:46:06
The cover on the side behind the distributor was leaking so I ordered a new gasket. It came today, but it has a rectangular hole it it on the bottom right. Its about 1" high buy 3" long. The gasket I took off was solid, no hole. Should I put it on or is it the wrong gasket.I did get the three little rubber gromets also.
Tim
Tim 12138
05-26-2007 18:29:02
 Re: 860 side cover gasket in reply to Tim12138, 05-25-2007 18:46:06
Thanks guys, I put the gasket on and no leaks from the cover. My rear seal still leaks though. I've had the pan off 3 times in the last 3 weeks and can't cure the leaking problem. I guess I'll use a bra wired under the leak, and after I finish mowing I'm takeing the tractor to the sale, I'm sick of it.
Tim
john in la
05-26-2007 08:55:09
Many gaskets are built with extra holes so it can be used on differant applications. If the outer edge of the gasket fits the cover use it.
Fordfarmer
05-26-2007 07:11:40
I just put the same gasket in my 850 last week. Ran it a couple hours yesterday, no leaks. Go ahead and use it.
