Order Ford 971 Parts Online
1971 2000 p/s psi
Dan (wi)
05-16-2007 19:42:30
Helping freind with power steering issue. What kind of pressure should I have? Some wear in pump where the gears turn,no leaks,new filter,rams run in & out with front end jacked up. Any help appreciated, thanx Dan
Weldin man
05-16-2007 19:57:25
 Re: 1971 2000 p/s psi in reply to Dan (wi) , 05-16-2007 19:42:30
Without going to the service manual to check for sure,I think its 1050 to around 1100 psi at at 1000 RPM. My experience with Ford pumps, if they have much visable wear at all they will not make enough pressure. Gears,Housings and Etc. are no longer available from New Holland to repair them.You have to replace the whole Pump.
