Order Ford 860 Parts Online
860 timing push rods
Kevin Matheson
04-27-2007 07:06:37
I just got done with the overhaul on my 1955 Ford 860 (runs great). Last night I was going to set the timing and couldn't find any timing marks on the flywheel. could this have been replaced at one time with a flywheel with no marks on it? How do I know where the timing is set at?
the other thing I notaced when setting the valve lash one of the push rods was not rotating, just moving back and forth a little. Is this a problem and if so how do I fix that?
Thanks
Kevin
duck64759
04-27-2007 17:09:18
 Re: 860 timing push rods in reply to Kevin Matheson, 04-27-2007 07:06:37
The marks are not on the flat of the flywheel as you look straight into the hole, they are on a ridge or the step up on the flywheel. I took the advice of others here & removed the starter cause the hole is bigger to see the marks. Turned the motor over till I found the marks, marked them, put it all back together. I at first thought my flywheel had no marks, but after removing starter & looking there they showed up pretty plain.
john_bud
04-27-2007 07:26:07
The timing marks may be covered with years of goop and slime. (yuck) Hand rotate the engine so the #1 piston (closest to radiator) is ready to fire. Then look for the marks. Clean as needed - carb cleaner & toothbrush etc.
You can static time it now. Rotate the engine so the flywheel is at the correct time. Then with the ignition ON, rotate the distributor until the #1 spark plug fires. (Put the cap back on, plug in the #1 plug, hand ground it or ground it with a wire from the block to the plug battery --> you can then see the plug spark). When you have it so it sparks, tighten down the dist and off you go.
jb
