850 vaper lock?
wompuscat
02-21-2007 19:07:20
was working my tractor fairly hard today, when she started to cut out. (acting like she was running out of gas) When I got off and looked at the sediment bowl, it looked like it was getting big air bubbles in it. 1 big bubble about every 3 or 4 seconds. Would this be vapor lock? And if so, is there an easy fix? Thanks in advance. BTW I had about a half a tank of gas in her.
steveormary
02-21-2007 20:40:29
 Re: 850 vaper lock? in reply to wompuscat, 02-21-2007 19:07:20
wampuscat
Old is right.Give the gas line some clearence between the hot spots. We had an 850 that would do that if it thought we were working it too hard
steveormary
old
02-21-2007 19:46:19
Do you still have the heat sheild between the tank and the engine?? If not thats your problem. Also check the gas tank cap vent if its clogged it will cause the same type of problems. Another thing is how the fuel line if routed. If it sits close to the manifold that can also be your problem
