851 Hydraulic pump leak
TnT
02-19-2007 10:22:44
I have an 851 Ford, 1957 year. The hydraulic pump is leaking where the supply and pressure manifold attaches. I replaced the seals this morning but it leaks worse now! I was going to get a set of misceleaneous "O" rings and start replacing rings progressively getting bigger till the leak stops. Any suggestions?
TnT
02-19-2007 14:57:08
 Part II the rest of the story in reply to TnT, 02-19-2007 10:22:44
It seems that the supply/pressure manifold was warped where it attached to the pump housing. I dressed it with a hand file and that stopped the leak. It's aluminum so I didn't want to take too much off. If it warps again I'll replace the pipe.
RoNofohio
02-19-2007 13:26:45
 Re: 851 Hydraulic pump leak in reply to TnT, 02-19-2007 10:22:44
When I replaced the o"rings in mine, I read on this forum to make sure I got the proper o"rings from a Ford Dealer. They were kinda expen$ive. I think I remember that one was made from oval stock and the other was from square stock. Anyway, no leaks...Ron
souNdguy
02-19-2007 11:01:50
Did you use the OEM CNH orings.. or tisco generocs? The CNH orings, in some cases, are 'bigger' for the same application..
Also.. did you clean upt he surfaces good/
Any cracks?
Soundguy
