Order Ford 601 Parts Online
EAE 6015-F WHAT IS IT?
ROBERT VAUGHAN
01-19-2007 06:54:45
I HAVE JUST BECAME THE NEW OWNER OF WHAT APPEARS TO BE A FORD JUBILEE TRACTOR. I HAVE LOOKED ON THE BLOCK AND LOCATED SEVERAL NUMBERS, WHICH ARE EAE 6015-F AND BELOW IT WHAT APPEARS TO BE 35S’2= C. I DON’T HAVE ANY BOOKS FOR THIS TRACTOR AND I ALSO NEED TO REPLACE THE PTO SHAFT, BUT FIRST I NEED TO KNOW WHAT KIND OF TRACTOR AND MODLE TO ORDER THE MANUALS AND PARTS.
VAUGHAN, FLA.
Carl Wells
01-19-2007 07:24:04
 Re: EAE 6015-F WHAT IS IT? in reply to ROBERT VAUGHAN, 01-19-2007 06:54:45
Look right behind the starter there is a flat spot where the model and serial number should be, you may have to clean it to see it. Oh and please take the caps lock off , your message will be more reader friendly.
Robert Vaughan
01-19-2007 08:19:50
 Re: EAE 6015-F WHAT IS IT? in reply to Carl Wells, 01-19-2007 07:24:04
Carl, thanks for the that information, I'll look for that this weekend.
Robert Vaughan
01-22-2007 07:13:20
 Re: EAE 6015-F WHAT IS IT? in reply to Robert Vaughan, 01-19-2007 08:19:50
I looked behind the starter for the modle and SS# for my newly Jubilee tractor. The only numbers that I have been able to find are NAA 4024-C which was under the seat area and NAA7006-B which was on the other side of the tractor below the gear shifter. Hopefully, behind the starter doesn't mean that I have to pull the starter out to locate the numbers? Behind the starter and the transmission was an area that appeared to have an plate attached but is no longer there, would that have been where the ID numbers would have been? If so, are there any other numbers which could help me to ID it?
Vaughan, Fla.
