Order Ford 2000 Parts Online
Ford 2000 Model #20303 Serial # 131382
Christian
10-17-2006 15:06:28
Have a Ford tractor with a decal saying its a Ford 2000 Industrial. I thought it was a 2000 built in 1963 or there abouts. Whats the 2nd and 5th digit of the model # represent? Want to add a PTO to it and wondering if it came with one (model 20303) and the shaft was removed?
Thanks,
john in la
10-18-2006 01:33:51
 Re: Ford 2000 Model #20303 Serial # 131382 in reply to Christian, 10-17-2006 15:06:28
Your tractor is a 2000 industrial. The orginal color would be the red/orange of the 601/801 and Buff (yellow).
The model # breaks down like this.
2----- 2000
0----- built before sept 1962 (63 model year)
30---- industrial tractor
3----- 4 speed with gauges; hyd system; and PTO
The 20302 has hyd and NO PTO.
Your serial # tells me you have one of the last tractors built in 1960
The first serial # for 1961 is 131427
christian
10-18-2006 04:07:04
 Re: Ford 2000 Model #20303 Serial # 131382 in reply to john in la, 10-18-2006 01:33:51
Thanks for that info John now to take a peak as to why there is no PTO shaft.
Thanks CJ
john_bud
10-18-2006 07:42:50
 Re: Ford 2000 Model #20303 Serial # 131382 in reply to christian, 10-18-2006 04:07:04
It's possible that in the past 40 odd years, the transmissions were swapped and the numbers may not mean anything relevent.
If you pull the square PTO delete plate, and look in there and can see all the way to the center section, then it used to have a PTO. If you see a plug like a frost plug at the interface between the differential and the hydraulic section, then it never had a PTO. That plug was put in there by the factory to seal the two sections on tractors with no PTO.
Probably simpler, is to see if you have a PTO engage lever on the left side of the differential. No lever, probably never had a PTO.
jb
christian
10-19-2006 16:36:28
 Re: Ford 2000 Model #20303 Serial # 131382 in reply to john_bud, 10-18-2006 07:42:50
Tractor now has a PTO that works. That was easy.
