Order Ford 860 Parts Online
860 remote valve-can be used for singal acting ram
MartinG
08-11-2006 20:18:44
third party image
My 860 has a remote valve that I believe is double acting. The I&T manual says there is an adjustment screw to make it work with single acting rams. One of the hyd. lines is clearly marked "LIFT" I assume this would be the line to use for single acting action. I would like to move a trip type manure loader off my 850, it works off the tractor hydrls and 3 pt lift lever. Does anyone know about this remote valve? Thanks for any help More pics at the link listed below
MartinG
08-14-2006 05:53:45
 Re: 860 remote valve-can be used for singal acting in reply to MartinG, 08-11-2006 20:18:44
Thanks for the info. This is a great forum.
duckrock
08-12-2006 20:18:29
I have the same valve on my early 4000 (4cyl) that is not running right now. I want to take it off and put on my 800. Can someone tell me how to do this?
Dean
08-13-2006 01:30:56
 Re: 860 remote valve-can be used for singal acting in reply to duckrock, 08-12-2006 20:18:29
This is a bolt-on conversion as the hydraulic valve mounting plates are identical. All you will need is 2 new sets of O-rings. The O-rings are not special and should be available at any good auto parts store as well as you CNH dealer.
Just remove the 4 bolts holding the valve to the lift cover on the 4000 and the 4 bolts holding the block-off plate onto the lift cover on the 8xx. Swap the valve and block-off plate, install new O-rings, and you should be good to go.
Dean
GWB111
08-13-2006 07:10:25
 Re: 860 remote valve-can be used for singal acting in reply to Dean, 08-13-2006 01:30:56
Let the three point down before you unbolt the valve.
Hurley J. D.
08-12-2006 07:08:34
See the hex head slotted screw on your valve. Screw it counterclockwise for single acting cyl. Screw it back in for double acting.
