woods RM 306 finish mower
Dan Monigold
05-22-2006 06:52:56
Hello, I am looking at a Woods RM306 5 ft finish mower , probaly around 15 years old but in very good condition. ( stored inside , newer blades and drive belt).It was used by an older gentlmen to mow a large open part of his lawn using a 8n to pull it. The mower has not been used for three years and was stored inside.Does any one have any experiance with this type of mower. I have always had good luck with woods stuff. I want to put it behind my Ford 4000 and mow some open areas behind my out buildings and some walking paths. The price is $475 which is not as scary as the $1500-1600 that I have been seeing with new versions
Rick Kr
05-23-2006 09:45:40
 Re: woods RM 306 finish mower in reply to Dan Monigold, 05-22-2006 06:52:56
Dan,
I had a RM305, 5 footer, with the chains in front.
It was 20 years old. Stored inside, well used but not abused. Mowed about 6 acres a week with it. Just sold it for $550.
Rick
ScubaInstr
05-22-2006 09:39:01
Dan,
If I"m not mistaked, the Woods RM-306 is a 6" mower, not a 5.....Atleast my RM-306 is 6".
I use it with a Ford 4000 (64 model) and the only thing I don"t like is the fact that it rides on the 3 point all the time. Makes it scalp when the tractor rear dips into a low spot, and it cuts real high when rear goes over a high spot. Excellent mower though.
Good Luck!
Tommy D.
Beargap
05-23-2006 03:30:50
 Re: woods RM 306 finish mower in reply to ScubaInstr, 05-22-2006 09:39:01
I, too, have a Woods RM-306 and have it on a Jubilee with limiter chains. Works fine and the 6' width speeds cutting up, but I also get problems with scalping that I don't get with the 5' Woods belly mower on my Cub. Have you looked into the front wheels for the RM-306 or the front roller? Both are available, I think, from Woods and I wondered if either was good at reducing scalping.
=Vic=
Bear Gap, PA
Dan Monigold
05-23-2006 06:05:32
 Re: woods RM 306 finish mower in reply to Beargap, 05-23-2006 03:30:50
I was looking at the manual from woods and it claims the rooler will stop scalping . I think i will try one on this mower.
Dan
Beargap
05-24-2006 04:46:40
 Re: woods RM 306 finish mower in reply to Dan Monigold, 05-23-2006 06:05:32
If you get that roller, let us (me) know how it works. I think I will check on the prices, too.
=Vic=
WA4THR
Bob N.Y.
05-22-2006 17:18:56
Mine has chains that attach to the front of the mower and up to the top link on the tractor. Do you have those?
Dan Monigold
05-22-2006 11:42:53
Your Right ! I WAS ONLY OFF BY A FOOT!....ha
I double checked it is a 6 foot mower , which makes me like the deaL even more.I got a manual from woods web site and have been reading at work. Woods claims that all the parts are still available.Sounds like this will work fine for what I want and is a lot cheaper than the new versions.
Thanks for pointing that out
Dan
Ford Puller
05-22-2006 09:28:55
Can you narrow your 4000 enough so that the rear wheels are not outside the cutting path? It looks to me like I can only get my 961 to 68 inches outside to outside (54" center to center).
