Order Ford 860 Parts Online
860 tranny problems
dlc
05-06-2006 12:17:43
Have a 56 Ford 860. The tractor was sounding fine then suddenly the tranny started to make a whamp whamp noise that is in frequency with the speed of the engine. The noise stops when the clutch is depressed. If you move the tractor it will move but make the noise while moving, when you let up of the clutch while moving that tractor will stop quickly like something is holding the tractor back. Got any ideas. Also seems that the tranny is full of hydralic oil, isn't it supposed to have gear oil in it?
dlc
05-13-2006 15:00:02
 Re: 860 tranny problems in reply to dlc, 05-06-2006 12:17:43
Thanks guys, I also think it's likely a bearing that's gone bad. I was already planning on tearing the whole tractor down anyway.
Dave H (NY)
05-07-2006 15:19:46
Does the clutch pedal feel sticky? Do you have to sometimes put your toe under to pop the pedal up? If so then it's a good possibility the clutch fork is bent and not releasing properly.
awhtx
05-06-2006 16:47:58
It sounds like a bearing has gone bad in the transmission. Perhaps you can remove the shifter and the cover plate and find the bad bearing inside. It sounds like you're looking at a complete teardown. It's not that difficult- I did my 861 a couple of years ago.
Ford recommends the use of 134D hydraulic oil in the trans, hydraulics and rear axle.
Larry NCKS
05-06-2006 20:06:29
 Re: 860 tranny problems in reply to awhtx, 05-06-2006 16:47:58
Originally the transmission and rear end had gear oil in them. It is still acceptable and I prefer it in the rear axle. However, new wisdom says use hydraulic oil throughout.
