Order Ford 2600 Parts Online
1981 ford 2600 tractor
wimpee
12-20-2005 08:35:11
i thought i had asked this a week ago but i couldn't find my message. i have a leaking shut off valve below the gas tank and can't get it to shut off and it continually leaks on the ground. does the valve unscrew from the part that is connected to the tank?
if not, does the part that is connected to the tank screwed into the bottom of the tank or welded into it?
where can i buy a replacement for the parts i need?
thanks,
pat in texas
RWK in WI
12-20-2005 17:25:09
 Re: 1981 ford 2600 tractor in reply to wimpee, 12-20-2005 08:35:11
The part that screws in an out, is kept from turning too far out by a "U" or "C" shaped clip slipped in from the top. Remove the clip and you can unscrew the valve part. Once in a while you will be lucky an be able to clean the inside of the valve and reassembe. There may be a O-ring that is repacable also.
I hope this helps you.
Hurley J. D.
12-20-2005 10:40:07
You can buy the part at places that sell tisco parts. The best valve will come from New Holland. The valve will unscrew from the bottom of the tank. The boss that is on the tank is welded to the tank.
wimpee2
12-20-2005 12:43:36
 Re: 1981 ford 2600 tractor in reply to Hurley J. D., 12-20-2005 10:40:07
thanks j.d. - came right out like you said - dang it helps when you ask someone who knows something. i really appreciate you replying.
