851 steering question
TnT
12-17-2005 19:43:17
I'm attempting to install a Jackson Power steering unit on my 851 Ford. I have removed the steering wheel and the hold down bolts for the top part. I'm having difficulty getting the steering shaft out. Is there a keeper of some type or am I simply not applying enough force to remove the shaft? Thanks for the help.
Roland Jackson
12-17-2005 19:57:00
 Incorrect phone number...should be 620-357-6546 in reply to TnT, 12-17-2005 19:43:17
Jackson Power Steering Service Number is 620-357-6546.
Roland Jackson
12-18-2005 08:02:06
 Steps to remove the worm gear from the steering ge in reply to Roland Jackson, 12-17-2005 19:57:00
Hi, I haven't been able to get in touch with you, so thought I would write down some steps in removing the worm gear from the steering gear box...now that I am in the office and not on my lap top. I don't know if I will ever get use to typing on a lap top! Anyway, this is the way I remove the wormgear.
1) I jack up the tractor so the front wheels are off the floor.
2) Remove the steering wheel and the steering column.
3) The steering shaft and worm gear are only restricted from coming out by the sector gears. So if you can wiggle the steering shaft and turn the front wheels (sitting down in the tractor and pushing the drag rods with your feet) the worm gear will come out.
Looking forward to hearing how the installation went and how you like Power Steering on your tractor.
Best Wishes,
Roland Jackson
Roland Jackson
12-17-2005 19:50:03
 Re: 851 steering question in reply to TnT, 12-17-2005 19:43:17
Hi...just call me...620-357-5645..and I will talk you through it. Call me any time as I want you to have an easy installation...your hours are my hours.
Best wishes
Roland Jackson
www.jacksonpowersteering.com
