851 injector pump...broken shaft!!
jwill
05-01-2005 18:33:46
Just replaced the pump...cranked up and ran for about 30 sec and then sheared the pump shaft!Any thoughts??
Gary Alford
05-13-2005 10:26:27
 Re: 851 injector pump...broken shaft!! in reply to jwill, 05-01-2005 18:33:46
I've seen the exact same thing happen on a John Derre and it was a plugged injector that caused it.
Rod F.
05-02-2005 18:37:10
Something has caused the pump to bind up rather solidly. I would consider the possibility that some water entered the system. Water won't inject, and can often blow the injector tips off. It wouldn't surprise me if it would cause damage similar to yours. That's not necessairly the case, but it wouldn't hurt to drain the fuel tank and make sure it's clean, change the filter, and purge the system. That way, when you have the pump repaired, and the injectors checked, you'll have fewer things to worry about when it's reinstalled. Good luck.
Rod
ERIC BENTON
05-02-2005 06:46:50
Pull your injectors and have them pressure checked. One or more of them is plugged up and it causes a build up of pressure that shears the shaft in the pump. This usually ruins the head in the pump when it happens so you will have to have the pump rebuilt again.
Roy Suomi
05-01-2005 20:03:47
Something seized inside of pump. Head and rotor probably.Was pump rebuilt or used??I ran into that on a Deere 690-A.. Ran strong for about 2 minutes after replacing with a rebuild unit.
