Order Ford 860 Parts Online
860 Steering Coloumn leak??!!
Mike-UT
03-06-2005 20:37:04
I hope one of you experts ca help me out...I changed my voltage regulator..to gain access I removed the steering wheel, and instruement panel. After reinstalling everything, I fired it up, took it for a drive..ande noticed that oil was dripping down on my starter switch. After investigating it;s source, I found that's it's coming out of the top of the steering column.(right under where the steering wheel mounts. I rechecked the steering wheel, it is tight..Any advise on what might have happened...and what I'm going to need to do to fix it?? Any advise will be most appreciated.
Larry NCKS
03-07-2005 05:17:02
 Re: 860 Steering Coloumn leak??!! in reply to Mike-UT, 03-06-2005 20:37:04
I take it you have power steering. Likely a steering gear box reseal is needed in this case. If you do not have power steering, you've got something really strange happening. HTH
Mike-UT
03-07-2005 09:20:38
 Re: 860 Steering Coloumn leak??!! in reply to Larry NCKS, 03-07-2005 05:17:02
Yes, it has power steering.In the manual I have, it shows the steering mechanism as in 3 sections. Are you thinking it's in the control valve assembly or the steering gear housing? Thanks
Pernell
03-07-2005 11:24:58
 Re: 860 Steering Coloumn leak??!! in reply to Mike-UT, 03-07-2005 09:20:38
It's just the seal in the bottom of the tower, but when you remove the 3 bolts to replace it, do not disturb the valve body or you will have to go farther in to it.
Mike-UT
03-07-2005 20:40:41
 Re: 860 Steering Coloumn leak??!! in reply to Pernell, 03-07-2005 11:24:58
Got it! I'll be careful not to disturb the control valve area. Would you happen to know where I could get this seal? Is it called the "lower tower seal"? Thanks a million for your help. If I had half the money I've saved from from the kind of help I've gotten from this site from guys like you, I'd give you half of it...but I don't, I spent it on my Tractor! Cheers!
Pernell
03-08-2005 08:54:10
 Re: 860 Steering Coloumn leak??!! in reply to Mike-UT, 03-07-2005 20:40:41
I've got the seal Part# E1NN3N632AA $9.16 and o-ring Part# 1707280 $1.27.
Mike-UT
03-08-2005 18:31:33
 Re: 860 Steering Coloumn leak??!! in reply to Pernell, 03-08-2005 08:54:10
Pernell, I'll buy them from you..how do I go about it?? Thanks.
