Order Ford 860 Parts Online
860 Hydraulic problem
Jerry Cent. Mi.
01-07-2005 05:23:08
The front end loader on my 860 will not stay in a set position. I set it at a certain height and when ever it feels like it the darn thing takes off and goes clear to the top. Hard to trust it inside a low clearance area. Anyone else experienced this problem?
Roy Suomi
01-07-2005 21:37:36
 Re: 860 Hydraulic problem in reply to Jerry Cent. Mi., 01-07-2005 05:23:08
Sounds as if the valve centering spring isn't centering the valve spool when you're not using the valve.The spool should work smoothly for raise and lower positions , with spring tension centering the spool in the neutral position. If not, remove the end cap to see if the spring is broken. Watch out for possible loose ball bearings that might fall out . These ball bearings hold the spool in the float position.
