851 Ford Hydraulic ?
TnT
12-31-2004 15:01:18
I have a 1957, 851 Ford tractor. The Hydraulic system is difficult to keep adjusted. Is there any fix for the inevitable drift down or is that just something you have to live with? The draft control has me completly baffled and the operators manual is no help. When I mow the mower will hold at one level but it"s jut a little too high, When I get it where I want it it keeps drifting down every few minites. I haven"t got a disk for it yet but that"s next. I should sell tickets when I use the box blade. I fixed the hard to start problem. Harolds tractor in Wichita Falls cleaned out the mixer valve and the regulator on the propane system and installed a new coil. It starts first time every time now. He did a lot of work and didn"t charge me a lot of money. No wonder he has been in business so long. Plus he helped me load the tractor and tie it down.
Dave H (NY)
01-01-2005 04:03:38
 Re: 851 Ford Hydraulic ? in reply to TnT, 12-31-2004 15:01:18
Don't use the hydraulics in draft mode unless you are plowing with a bottom plow, use position control. A set of mower chains will maintain your depth setting.
