Order Ford 841 Parts Online
Oil Pressure Variation on 841 Diesel
1st 801
11-22-2004 13:08:53
Just bought tractor and was concerned about oil pressure when hot: 10-15 idle and 40-45 hot or cold @ 1400rpm.
Pulled pan to check bearings,etc.and found the nut and seal missing on the line from the pump to the main gallery.
Checked all bearings while in there, almost new: 0.002-0.003 clearance - 0.005 of crank end play.
Replaces seal and nut and new pump. The relief valve was stuck in new pump and pressure would peg 80# on gauge. Oil filter gasket would leak. Put warranty pump on. Now have 70# cold/45# hot.
When you start up small incline, pressure drops 20#. When you start down hill, pressure increases 20#.Am concerned about pick up screen against bottom of oil pan. Could this be it?
ErnieD
11-22-2004 16:20:33
 Re: Oil Pressure Variation on 841 Diesel in reply to 1st 801, 11-22-2004 13:08:53
Is the suction pipe a press fit into the pump? Air leak...
Your numbers are good except for up and down hill.
txblu
11-23-2004 06:10:24
 Re: Oil Pressure Variation on 841 Diesel in reply to ErnieD, 11-22-2004 16:20:33
Agree.
