851D head gasket kit question.
lotaquestions
11-13-2004 08:42:20
When I disassembled the head on my 851-D,only the intake valves had oil seals. I think you call them a top hat style seal. The new upper end gasket kit I purchased came with 8 of these top hat seals. I assume 1 for each valve. IThe kit also came with 4 similar looking rubber things. What are these things? where do they go? What do they do?
lotaquestions
11-14-2004 04:42:57
 Re: 851D head gasket kit question. in reply to lotaquestions, 11-13-2004 08:42:20
These rubber things that look like a valve seal, slide down over the valve stem just like a normal seal, they don't quite fit correctly over the top of the valve guide top. If I turn them up side down on the exhaust valves they mate nicely with the underside of the valve spring retainer. Could these rubber things be used to assist in holding down the exhaust valve seal?
