851 Wheel bearings
Skycarp
07-25-2004 16:54:46
I have a Ford 851, General Purpose. The s/n is 3664. The wheel hubs have a part number in the casting of NCA-1106-B.
According to the Ford Parts Manual the correct bearing/retainer kit for this tractor with early s/n is CBPN-1200-B. When this kit arrived from the parts house I found that both inner and outer bearings are wrong. They are too tall and too large in diameter to fit in my hubs. The seal/retainer is correct though.
Can anybody help me out in ordering the correct bearings for these hubs?
john in la
07-25-2004 18:09:57
 Re: 851 Wheel bearings in reply to Skycarp, 07-25-2004 16:54:46
Are you sure that is not NCA-1104-B
They show two differant ones for the 800.
One is before serial #137818 with hub NCA-1104-C 1953-1956
Then one is after serial #137818 with hub NCA-1104-B 1957/
Then in 1958 on 801's they changed to a third one. 1958/ They do not show a hub # for this one. Since yours was built in 1957 it may have either the late 800 hub or the 801 hub. Hard to say.
They have a 4th listed but it is for the industral front end 801.
This is why when I bought my bearings I took them to a bearing seller and had them measured. I can not put my hand on recite right now but if I can find it I will post back.
skycarp
07-25-2004 18:54:29
 Re: Re: 851 Wheel bearings in reply to john in la, 07-25-2004 18:09:57
John,
I am sure of the part number on the hubs. I sandblasted both hubs and they both are the same number. I thought the 6 was an 8 until I took off the old paint. It is a 6 for sure. And I ordered from the parts book as if it was a late 800 or an early 801. That didn't work for me.
If I don't get some help from a New Holland dealer tomorrow, I will do the same thing you did, go to a bearing house and have them match up the bearings.
Thanks for the reply,
skycarp
john in la
07-26-2004 07:10:56
 Re: Re: Re: 851 Wheel bearings in reply to skycarp, 07-25-2004 18:54:29
OK went and looked at my hubs on my late 57 or early 58 861 this morning. It says NCA-1106-B the same as yours says.
The bearings I bought was from American Bearing. The recite says..... ..... .
Tim-Set2..... ..... 2each..... .12.98
Timken
Tim-Set6..... ..... 2each..... .15.40
1-LM67010,....1-LM67048
CRI-16842..... ..... 2each..... .18.56
1.686" X 2.686" X.312" seal
Total..... ..... ..... ..... ..46.94
Hopfully this will help you get the right stuff.
