Order Ford 640 Parts Online
Yes it can be done-640 studs
Larry-NEK
07-18-2004 17:23:20
third party image
A while back I posted a question about replaceing rear wheel studs without pulling the brg. or backing plate. Someone said you could drill a hole but didn't know where. Well I just did it with ease, using a 1" hole saw and an air drill. Then plugged the hole with a #6 rubber stopper. Hay it works for a working tractor,mite not want to do it to a show rig. Just FYI Thanks- Larry
john in la
07-18-2004 17:46:41
 Re: Yes it can be done-640 studs in reply to Larry-NEK, 07-18-2004 17:23:20
Thanks for the heads up Larry;
I am the one that told you that manual said you could cut hole and plug. I need to get back to doing mine if I could just narrow down the honey do list a little.
By the way here is your pictures;
third party image
third party image
third party image
Kens640
10-08-2004 06:32:27
 Re: Re: Yes it can be done-640 studs in reply to john in la, 07-18-2004 17:46:41
Hey John , can ya send those pics to my email addy so I can print them out for future use ? I had them in my file once but this system crashed & I lost everything . I haven't learned how to burn my files & pics onto disc yet . Thanks , Ken C
Larry-NEK
07-19-2004 09:03:39
Thanks John for getting the photos to appear. And good luck with your stud replacement , it went quite well ,the air drill took up less space so Ididn't have to pull the fender off. There is a dimple between the brg. retainer bolts at 12:00 that the 1" hole saw fits nicely in. thanks again -Larry
Larry-NEK
07-18-2004 17:27:41
Sorry , I tried to post a photo but it didn't work . I was able to post them on the Tractor Photos Gallery. Thanks - Larry
George H
07-19-2004 23:16:39
 Re: Re: Yes it can be done-640 studs in reply to Larry-NEK , 07-18-2004 17:27:41
Thanks to both of you.
