Hi again folks,For those of you that haven't read my earlier thread, I'll give a very brief history. My 860's hydraulic system had problems. If I shut off the engine with the lift in the up position while there was an implement attached to it, it would leak down to the ground in about 9 or 10 minutes. The lift would work properly when I restarted the tractor. If I put the lift in the down position and shut off the tractor, the lift arms would not even try to lift and I would have to bleed air from the pump and then from the remote on top of the lift plate. In both senarios the lift would raise in a jerky motion. I asked for some advice and help on this board and got some very good responses. Based on those responses I purchased an O-ring kit for the lift plate, and replaced all of them that I could. I did NOT tamper with the valve located inside the cylinder housing. Is this the unloader valve? I'm not sure. I drained the fluid and cleaned out the reservior. I then refilled it with 134 fluid from the NH dearler. I did all of this at the same time, and nothing changed, the lift would still malfunction. I then replaced the Safety Vavle. It's the one located under the accessory cover on the lift plate, according to my NH dealer. I asked for a check valve. They didn't know what I was talking about. So looking at their pc with an exploded view, I pointed it out to them. They said that was called the Safety Valve. Anyway, I replaced that, and still there was no improvement. Today I loaded it on the trailer to take it to a friend's house to do a little bit of bushhogging. While it was sitting on the trailer idling, I noticed a fluid leak that had never been there before. This tractor had no leaks prior to this one. Well, it was leaking from the spool on the remote accessory plate. I shut off the tractor, removed the spool and saw what appeared to be an o-ring groove, but there was no o-ring there. I went to the store, bought an 0-ring, installed it, and guess what? It has now been about 8hrs and the lift has dropped only about 3 inches. The o-ring that I installed was not the right size. It did not fit on the OD of the spool, and it was too big for the ID of the housing. So I assume that it is compessed somewhat and thus sealed on the spool. I will however get the proper one tomorrow and hope it cure the lift 100%. If it doesn't, I'll ask for more advice. Thanks for listening, and I hope that this might help someone else diagnose his hydraulic lift woes. Gil
