Your welcome. Can't help with valve location as I never had to change one (they were never my problem). The I&T manual shows functionally where it is. I know that one of them is in the front of the cover plate (right between your legs on top of the housing). You can't remove it without taking the cover plate off as the mounting flange (where the tranny and hyd sections mate) is in your way. I&T manual tells you which one this is. There may be one more place to suck air. Your tractor may have a filter screen (not filter per se, as they are usually on the discharge tube) in the sump, on the floor, on the right side.(just under and inboard of the 2 cover Orings we discussed. If this screen is clogged with crud, your pump can be sucking fluid but not getting all it wants. That lowers the atmospheric pressure of the oil and it "boils" so to speak. This creates a flood of tiny bubbles that could cause this problem. I have been into sumps from 2N thru 4000 so I don't remember which had filters and which didn't. If all else fails, this is something to try. Also (again not remembering the setup) if you have tubes (cast manifolds/combination of both) coming from the hyd section to the pump inlet/outlet, there are Orings at both the housing and pump interfaces that could be your problem. Good luck. Mark
