Hi folks, first let me say that I have tried the Archives Search feature for a few days now, and the Search feature is down, as most of you probably know. Otherwise, I'm confident that I could find a solution to my problem without asking. Anyway here goes.Draft/Position lever: Is up Position or Draft? My tractor's hydraulic system seems to work near flawlessly if I leave the lift lever in the up position when I shut off the engine. If there is an implement attached the lift arms will be in the lowered position in just a few minutes. However, as soon as I start the tractor the lift arms come up just as they are supposed to do. If I leave them raised as high as they will go the arms will "bounce" slightly. I have bled some air out of the hydraulic pump itself by loosening the pipe plug in the top of it while the engine was running, with the lift arms in the raised position. I then bled off some air at the remote plate under the seat. What do you think is the problem? Should I service the O-rings, checkball valve, cylinder, etc under the Remote plate as described at the website that I've linked at the bottom of this post? Is there a method to check the output of the hydraulic pump? We have high pressure guages at work, so putting together an aparatus to test pressure won't be a problem. What is an acceptable range or minimum pressure? Is there a kit that my local NH dealer sells to service the parts under the Remote plate? I don't have a manual yet, so how about the drain/fill locations for the hydraulic reservoir? Does this tractor have a hydraulic filter? If so where? The fuid looks like used motor oil, so I know that it is way past its useful life. Replace with NH 134? I know, I know. Questions, questions, questions. But that's why I have asked you guys, because you know the answers. :-) Thanks a bunch, like I said, had the Search been working I would have read and read before posting. Gil
