850 slow hydraulics when warm.
PhillipM
05-31-2004 23:34:25
My 850 with a piston pump works great from cold start till 1/2 hour run time. Then it gets real slow and weak. I have to back up at the end of a furrow with a plow to get it to raise. Acts the same in position or draft control. I have fresh 134 oil, and no bubbles at the pump. With the 2x 14 plow raised, warm or cold, the arms surge up and down a fraction of an inch. Position control is hard to set just right. Sometimes it will allow the implement to slowly drift down a little.
Dave H (NY)
06-01-2004 04:14:51
 Re: 850 slow hydraulics when warm. in reply to PhillipM, 05-31-2004 23:34:25
I was haveing hte same problem with my 850, I changed the o-ring and washer on the hydraulic piston as well as all of the other o-rings that I could find and so far no more trouble.
