Jerry, Thanks for your reply to my request for parts. I just starting out on this tractor and am not real knowledgeable on it, but from what I can gather from looking at the Ford tractor shop manual, my tractor is a general purpose, with power steering. In looking at the manual on wide front adjustable axle tractors there seems to be a different system for steering and the front axle support assembly, and the center axle appear to be different in these two tractors. My general purpose has two drag links running from the steering box that attach to spindle arms, that attach to spindles contained within outer left and right axle halves. The center housing and center axle member seem to be different on my tractor than on a tractor with the wide adjustable front axle. Can you confirm this, or does the wide front tractor use the same parts? Are pictures of front end on the 900 you refer to a possibility? Thanks for your help in this need,
