Order Ford 860 Parts Online
860 Power Steering
Bob
03-25-2004 19:30:21
I have a Ford 860 with power steering. Replaced one badly leaking PS cylinder (also had bent rod) with new cylinder. Hooked it up to pump, but turns very stiff to that side. Tried to bleed air out of PS hydralic lines, but didn't help much. Old PS cylinder, on other side seems to work great. New cylinder is a match of old part ( rod size, etc.). Any suggestions on what I'm doing wrong? Thanks.
WALTER
03-26-2004 04:06:01
 Re: 860 Power Steering in reply to Bob, 03-25-2004 19:30:21
Are you sure that the part numbers are the same on the replacement cyl as the orfice size in the one you installed could be different, also check your hose to see if it has not collasped internally and causing a partial blockage to this side.
