I am drawing a blank about the horse power right now. I think it is somewhere around 52 hp. You might want to think twice about the tractor if it does not have a pto. Unless you buy it to use mainly as a loader tractor. It is very nice for that. You might be able to add a pto but it could get very expensive. Check to see where the hydraulic pump for the 3 point lift is. It will either be on the left rear of the engine with pipes running over the top of the engine and back to the right side of the transmission near the back of where your foot rests. There will be a round plate about 8 inches in diameter or so that the pipes from the pump attach to and go inside to operate the lift. If it has the pump on the left side of the engine like that then the pto that it would take would be a live pto. You would have to replace the clutch with a 2 stage one and probably add some shafts and gears to bring the power back to the transmission for the pto. You may even have to change the transmission main shaft. Lots of parts. It is possible that they put the 2 stage clutch and shafts in and all you have to do is put in a pto shaft. Probably not that lucky though. The other setup would be for an independent pto. There would be no pump on the left rear of the engine. There would be a plate in its place. About 4 or 5 inches by about 2 inches. The pump would be mounted in that 8 inch hole on the right rear of the transmission where I said that the lines went with the engine mount pump. This pump is all internal. Not much sticks out. It will have a small pipe running up to the flow control assembly above it. This is a dual pump. 2 pumps in one. A larger pump that runs the 3 point lift and a smaller one that runs a hydraulic clutch for the independent pto. It will also have the internal shaft from the engine coming back that drives the pump and also drives the pto shaft. It would probably be an easier job to add a pto on this setup. You would need the hydraulic clutch that goes under the top lift cover and the pto shaft and maybe not much else. Not sure. Check the model number and look it up. That will tell you how it was built. If it had a pto originally or not. If it has the rear of the engine pump I think I would pass on the tractor unless the price is right and you don't need a pto. Don't confuse this pump with the front end loader pump. That pump is located on the front crank shaft of the engine and only runs the loader. How much are they asking for the tractor? Look here for under production codes and model numbers. Link Hope this helps. Regards Gary
