Order Ford 860 Parts Online
860 starting problem solved
ken in wisconsi
12-22-2003 09:29:09
After being gone for two weeks we found 8 inches of show at the cabin, so plugged in the water heater on the 860 overnight. (6-volt system) Didn't fire. Gas dripping from carburator. Pulled all plugs and grounded to check spark. Weak yellow spark. Scraped clean all external connections at distributor, coil and voltage regulator. Fired right up. Dell says "keep 'em clean, bright and tight" and even 6 volt systems are just fine.
