Order Ford 600 Parts Online
Ford Model 3600 Overheating
Joe Cooley
11-09-2003 17:12:49
I have a 1979 Ford 3600 diesel tractor. I think it is overheating and when i let it run for about 30 minutes or so it heats up. When i decided to flush the radiator i put super-flush in it. When i drained it after 30 minutes the water in the block was very hot, the water in the radiator was still cool/cold.....is my thermostat stuck or what is going on? Thanks for you help!!
James Lentz
11-10-2003 00:27:55
 Re: Ford Model 3600 Overheating in reply to Joe Cooley, 11-09-2003 17:12:49
I have a 3500. All I did to mine was replace the water hoses. The top hose was colapsing. I do have a quistion. This tractor went with this place I bought. Can you tell me what years the 3500 was produced? Also it has a front end loader and heavy duty scraper, all in fine shape. What could it be worth? Thank You. James Lentz
jimmythecinch1@ev1.net
old
11-09-2003 17:50:47
sound like the thermostat, Try starting it up with out the rad. cap and watch in the rad. to see if the water ever starts to move around if it doesn't pull the thermostat and replace. hope this helps
Joe Cooley
11-09-2003 19:05:16
 Re: Re: Ford Model 3600 Overheating in reply to old, 11-09-2003 17:50:47
Thanks, helps big time..... I thought i had remembered you could do that but I had read something about having to have pressure to circulate....I think I was reading about something else at the time.
Nope water will not start circulating.....oh well looks like a thermostat replacement job. Any idea on a scale of 1 - 10 how hard this will be on a Ford Model 3600? Thanks again!!
Rod F.
11-10-2003 06:27:32
 Re: Re: Re: Ford Model 3600 Overheating in reply to Joe Cooley, 11-09-2003 19:05:16
Thermostat should not be a bad job. You should be able to swing the battery out, take the upper rad hose off, and then just take the thermostat housing off. Just two bolts. Clean it up, put a little silicon on the housing to stick the gasket in place, then the new gasket, and new thermostat and put in place. Just make sure it centers and fits properly. Taking the hood off is not much pleasure, unless the muffler comes off easy. That's wishful thinking. Doesn't hurt to change the rad hoses while you have everything drained out, unless they are in good cond. Good luck.
Rod
Joe
11-10-2003 08:37:46
 Re: Re: Re: Re: Ford Model 3600 Overheating in reply to Rod F., 11-10-2003 06:27:32
I guess I am lucky, underneath mounted exhaust. I think I will change both hoses as you suggested.....would hate to do it again soon!!
old
11-09-2003 19:35:20
I can only guess, but if its like my 801 it will not be much fun. May be easyer to pull the hood, but again I'm just guessing. I haven't ever work on one like yours but all engines work the same so trouble shooting is just about the same with them all. Hope this helps a little more
Joe
11-09-2003 19:52:34
 Re: Re: Re: Re: Ford Model 3600 Overheating in reply to old, 11-09-2003 19:35:20
it does help, i have the hood pulled off for today so i will attempt the thermostat on Monday after work!! Looks like dropping the alternator, and while i am there i think i will go ahead and replace the hoses.....hate to fix it and next year the hoses blow!! thanks for you help!!
