Order Ford 661 Parts Online
injector pump timing 6610
Mike
11-02-2003 15:26:36
Can anyone help I own a 1983 6610 with an in-line injector pump .
The coupling jioning the pump camshaft to the gear sheared the woodruff key throwing the pump out of sync with the engine . I removed the pump and the injectors and sent them to a diesel shop . The pump was recondtioned and fitted with a new coupling , then tested along with the injectors , I am now at the stage of reassembly .
Does anyone know the procedure for installation ? .
RogerC
11-03-2003 18:00:57
 Re: injector pump timing 6610 in reply to Mike, 11-02-2003 15:26:36
I don't have the spec handy but the basic procedure would be to first bar the engine in the direction of rotation to bring #1 cyl. up (on the compression stroke) to the proper degrees before TDC. If you go past the timing mark on the flywheel, back it up well past the mark and rotate it forward to line up the marks. Once that is set, line up the marks on the front of the pump (one on the hub, one on a little casting) and install the pump. Double check the settings just before final tightening of the gear bolts and again after tightening. Hope this helps.
