Order Ford 860 Parts Online
860 won't start/ no spark/ how to check coil?
John C. (ca)
08-31-2003 10:31:44
Hello
I have an 860 that won't start. I have converted it to 12v and the electronic ignition from Genesee (which works great). Has ran fine like this for over a year. I screwed up and left the key on last week and now I have no spark. I have 12v @ the coil, but no spark at the coil.
1. How do I check the coil? I would very briefly ground out the - side of the coil expecting to see a spark with none showing.
2. Could the electronic module be bad from having 12v applied to it for such a long time.
3. I am using a non resistor coil. Somewhere I think that I should have use a resistor type. am I wrong on this?
Thanks for any help
John C. (ca)
Dan
09-01-2003 00:17:59
 Re: 860 won't start/ no spark/ how to check coil? in reply to John C. (ca), 08-31-2003 10:31:44
I have the same setup that you seem to have. I used the Genesee kit and included the electronic ignition. If I remember right, the coil should ohm out at about 3, but I would think the easiest thing to do, would be to call Genesee and ask. Them guys know their stuff and in my opinion, they are the best.
Dan
ATW/WA
08-31-2003 11:41:20
John, Since you have electronic ignition the good news is, you did not burn your points! You should be able to measure the resistance across the coil: primary ~1 ohm, secondary ~4000-7000 ohm.
Yes by grounding the distributor side of the coil you should see spark from the high voltage lead off of the coil.
HTH ATW/WA
John C. (ca)
09-01-2003 00:08:44
 Re: Re: 860 won't start/ no spark/ how to check co in reply to ATW/WA , 08-31-2003 11:41:20
I'll give it a try in the morning.
Thanks Alot
John
