Cracked Transmission Case...FIX??????
RICK/GA
01-20-2003 16:25:24
I've got a 1956 740 row crop. I have about twenty inches of crack on the right side of the transmission that does not extend into the clutch housing. A result of a giant ice cube that was once in there. I recognize that the transmission housing is a structural component of the tractor but the cracks are small and more plate can be welded over the housing. Would this be the wrong way to go? I welcome all opinions. I hate to leave my model and serial number in some junk yard since nearly all of the tractor is original. Any advise would be greatly appreciated.
Earl S
01-22-2003 20:01:54
 Re: Cracked Transmission Case...FIX?????? in reply to RICK/GA, 01-20-2003 16:25:24
Contact www.locknstitch.com The best and stongest casting repair you can do yourself. Earl
kydavid
01-21-2003 19:18:57
I'd weld it, were it mine. Unless you are experienced with cast, take it somewhere that does it. It won't be cheap. I just got a box of cast iron rods, my cost was $2.00 a piece; stainless is even more but would be the "best" to weld cast. Then it will have to be preheated for a while. Won't be cheap but it will be right.
John.COLO
01-20-2003 19:35:45
Welded or not, it's strong enough. You just want it to stop leaking. JB weld could be a possibility. Or, a good cast welder can fix it and grind off the bead so you'd hardly know it'd been repaired.
Dave H
01-20-2003 19:16:36
I walked over a 740 case today It's empty and I wasn't looking for that I can check on it It's in central Iowa
RICK/GA
01-22-2003 13:11:10
 Re: Re: Cracked Transmission Case...FIX?????? in reply to Dave H, 01-20-2003 19:16:36
Please do check oner. It would make me feel better with the 740 model number on it for some reason. You can email me if you find out abouter.
Thanks!
Dave H
01-22-2003 17:11:51
 Re: Re: Re: Cracked Transmission Case...FIX?????? in reply to RICK/GA, 01-22-2003 13:11:10
It's suposed to be -10 this week-end but I'll get down there soon I'm still finding gold parts there I'll get the # off it
Van(WA)
01-20-2003 17:40:37
Rick, I would take it to a pro welder, and have him take a look at it! Don't know why it couldn't be "V" out and a bead or two run in it. With a little grind off, re-paint, look like new, luck to you..... .
Ol Chief
01-21-2003 04:14:17
 Re: Re: Cracked Transmission Case...FIX?????? in reply to Van(WA), 01-20-2003 17:40:37
A friendly suggestion.If you are thinking of having that crack welded better consider drilling a hole at the end of the crack.Reason;-most likely the heat of welding will very likely drive or extend the crack so you will be chasing it or extending the damage.Ask T-Bone or some other pro.
