FORD TRACTOR PULLING
CURT FORRESTER
01-02-1999 16:38:15
IS THERE ANYONE HER THAT PULLS FORD TRACTORS OR IS INTERESTED OR MAYBE WOULD JUST LIKE TO SEE ONE SHOW UP AT A PULL AND EMBARASS THE COMPETITION.LETS HERE FROM YOU.ANTIQUE OR NEWER STUFF ITS TIME TO SEE SOME FORDS AT THE PULLS
Mike
09-30-2003 06:35:30
 Re: FORD TRACTOR PULLING in reply to CURT FORRESTER, 01-02-1999 16:38:15
I have a 305ci four cylinder CNH engine making 350hp if anyone is interested in using this set up in a pulling tractor.
Hugh
01-27-2005 13:39:37
 Re: Re: FORD TRACTOR PULLING in reply to Mike, 09-30-2003 06:35:30
Hey Mike, I am pulling a Ford 5000 with a 268 cid diesel. We are planning to install a 5 "crank into this engine. I would be interested in your set up. send info.
Keep the Fords pulling
Keith Materi
01-08-1999 21:27:38
I have a completely original and stock 1957 Ford 960 which I have pulled with a couple of times at local shows. She weighed 3300 with me (175) and a full tank of fuel. There is a W-4 and a 1929 Standard that always beat me, but I am going to figure out how to add some weight, mess with the air in the tires, and some other stuff. They will pay..... .they will pay!
CURT FORRESTER
01-16-1999 15:06:15
 Re: Re: FORD TRACTOR PULLING in reply to Keith Materi, 01-08-1999 21:27:38
HEY HOW ABOUT ADDING A192 CU.IN ENGINE THEY ARE AROUND THEY ARE A INDUSTRIAL ENGINE WE BOUGHT A BRAND NEW ONE IN A PUT IT IN A64 4000 IT MADE ABIG DIFFERANCE IF YOUR INTERESTED IMIGHT BE ABLE TO FIND YOU ONE. EMAIL CLAIRE@INNERNET.NET
Gary H.
01-03-1999 16:40:19
There is a New Holland(Ford) pulling on the NTPA circuit. Its Denny Hafert from near Bowling Green, Ohio. He does quite well. Its called LETHAL INJECTION Phase 4.
Bob seND
01-03-1999 11:11:34
There is a Ford 6000 that is brought to some of
the tractor pulls in the upper midwest. It was at the Dalton,MN steam threshers' reunion last fall. I believe from the ads that it is quite modified.
RICK
01-02-1999 17:36:49
The N-newsletter summer of 98 had a pulling issue. Best one was colored picture on the cover of 841 with Elenco front drive axle doing a wheely on a pull. Probably still available.RICK
