Engine Block Uses/New TO-20
1LOBO1
01-14-2008 08:50:54
Typically how much does a used engine block run for a TO-20? Would I be better off buying a new one? What would that cost?
Richard L
01-23-2008 07:08:06
 Re: Engine Block Uses/New TO-20 in reply to 1LOBO1, 01-14-2008 08:50:54
I checked this site and did not see any listed. My next ideas would be to keep an eye on ebay as there was a person on this forum that bought a Z129 engine about 2 weeks ago. Then I would google "tractor parts" and I am sure you will get a lot of places to check and probably some fairly close to your location as shipping can add up fairly quickly now days. As quickly as tanks full of gas. I have found if you try not to be in a big hurry you will come across a better deal possibly. Good luck and please let this forum know how you are making out. Richard
Jerry/MT
01-14-2008 11:39:33
What"s wrong with your old one?
The blocks are out producton so there is no "new" block available unless someone has started recasting them. Good used bare blocks run $400-$600 and repaired blocks are in that same price range.
1LOBO1
01-22-2008 14:48:09
 Re: Engine Block Uses/New TO-20 in reply to Jerry/MT, 01-14-2008 11:39:33
The old block is cracked from top to bottom and was leaking coolant in the oil. The crankshaft seems to be fine as well as the sleeves. When I stated "new" I should have written repaired, good catch. I am having trouble locating one (block), do you have any suggestions? Thank you
