T0 30 sleeve bore
RockyMO
11-26-2007 13:51:20
I am wanting to have a set of adaptors made for my sleeve removal/installer tools that will fit the T030 engine. Does anyone have the measurements for ID and OD (or wall thickness) of the sleeves? I have never had one of these engines apart so I am not real familiar with them. I am intending to rebuild one next summer though and am going to try to have everything ready to go before tear down. thanks in advance,
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Massey Ferguson 2135
Oliver HG
Real tractors have tracks
Jim in OH
11-26-2007 14:31:23
 Re: T0 30 sleeve bore in reply to RockyMO, 11-26-2007 13:51:20
Stock bore for the TO30 is 3 1/4" (3.25").. oversize bores depend on what was done over the course of its life, but the maximum overbore (the only one available now) is 3 3/8" (3.375") TO20s have a maximum of 3 5/16 (3.3125")... The OD at the bottom is 3.682" on the TO30 (I forgot what it was on the TO20 but a little less).. If making plates to pull, I'd make a round stepped plate about 3.6" OD with two steps.. one at 3.25 and at 3.375.. but even a 3.5" square plate can be made to work.. you only have to pull about 3/4" and it comes loose... If you check the archives, I even did it with a cheap homemade wooden puller made of 2x4 pieces
third party image
Thread here:
Link
