Re: Ferguson TO-30 Rear End Oil
wellmax99
09-22-2015 10:48:29
The correct oil is GL-1 hydraulic/transmission oil. This is mineral oil based and has been around for a while. A lot of us have switched to motor oil which does not attract moisture like mineral oil does and causes ice in the hydraulics during the winter months. I am using 10w-30 in my To30, I am sure others will chime in on other choices. ********************
I refilled my TO35 with GL-1 90 weight mineral oil per the manual.
but as the tractor hydraulic pumps get older and a bit more worn, GL-1 is harder to pump in the winter months, Lift still works, but I have to wait a minute for the lift to work, motor needs to warm up anyway, so its not a problem.
if 10w30 oil works, then go for that, would be much easier on the old pump in the winter months.
in the summer months the lift jumps right up as it should.
