Nawlens Gator
Fifth and final thread.
I started 4 posts about a recurring hot coil issue on a '72 IH 140. It is 12 V neg ground with 10SI alternator, 12 V (3.1 Ohm) coil, and Pertronix electronic ignition. Tractor runs great for 30 min to one hour then spits, sputters, and cuts off. It won't crank back up. I notice the coil is red hot when this happens and the ammeter shows a large current drain. The tractor will not restart. I switch the key off and after things cool for around 30 min it cranks up, all seems normal, and things repeat. I’ve installed new coils several times included the Pertronix recommended coils and an ic14SB coil from Napa and a new alternator.
Tested all the voltages and resistance and the alternator, 12 V coil, etc. all seemed normal. Most recently I installed a 1.6 ohm ballast resistor in the ign switch lead to the coil as posters suggested which dropped the coil input voltage from 11.5 to 8.5 V. Tractor mowed fine for 70 min (a new record) and the coil was only warm (I could hold my hand on it). That was encouraging.
At posters suggestion I measured dwell on the tractor yesterday and it stayed 58 deg through an 800 - 1400 rpm range. I don't think the lower input voltage would affect dwell but I could be wrong. I believe this is 57 - 65% more dwell than a 4 cyl engine with points which other posters claim is 35 - 37 deg. Neighbor and I then measured the dwell on another IH 140 and a '77 Cub that have similar EI's and Pertronix coils. Dwell on the other 140 was 54 deg and the cub was 58 deg. It doesn't look to me like higher dwell is the cause of the hot coils since I don't have this issue with the other 2 tractors. I thought it might be helpful to post this follow-up data. I hope it keeps running but I can't say what caused the issue in the first place.
That is all. - Gator out
