Farmall A front tires
'Bandit'
12-11-2000 15:22:56
I have a 1948 Farmall A. The from tire no matter which side it is on will slide on the hub until it cuts the valve stem off and the tire goes flat.
Only the one tire does it, i've put wedges around the rim, cranked the bolts that hold it as tight as possible but it still slides. I am figuring it is a mis-sized rim, were there more than one size rim for this tractor?
Thanks...
