Farmall A from tires
'Bandit'
12-11-2000 15:21:42
I have a 1948 Farmall A. The from tire no matter which side it is on will slide on the hub until it cuts the valve stem off and the tire goes flat.
Only the one tire does it, i've put wedges around the rim, cranked the bolts that hold it as tight as possible but it still slides. I am figuring it is a mis-sized rim, were there more than one size rim for this tractor?
Thanks...
gene b
12-12-2000 03:42:09
 Re: Farmall A from tires in reply to 'Bandit', 12-11-2000 15:21:42
tom is right weld a small piece on the rim that way it wont be able to slip older anes had a small piece from factory on there fits in the slot of the hub if you use fine thread grade 8 bolts tighten with impact usually will hold but the piece of metal is bullet proof
T.J.
12-11-2000 18:56:14
I`m not sure about A`s but on our M there are two blocks about 1/4 inch thick 2 inches long and as wide as center rib on the rim, welded on so there is one on each side of the wedge so it will not slip either way It was welded on by drilling a hole in just the block, and welded through the hole like a big spot weld.its factory I`m not sure if its IHC but it works Hope this helps Tom
DaveD
12-12-2000 20:49:41
 Re: Re: Farmall A from tires in reply to T.J., 12-11-2000 18:56:14
I always wondered why someone welded some nuts to the front rims of my B.....
