Re: 450 froze
caseman-d
04-03-2013 07:30:56
WOW,Sounds like you must of had the exhaust wide open to get that much moisture in. Since it's water you're better off than if it was antifreeze. Take a heat lamp or shop light and shine it close to the oil pan. Pull the drain plug and let the oil dry. You will be surprised how well that heat lamp will warm the pan and melt the ice. Once that is done change oil and filter, run, check and see if oil turns milky you will want to change again. No oil pressure could mean you ice block in line. You must be a lucky one to have that much moisture in your area.
caseman-d
