Re: 450 froze
rustred
04-02-2013 19:17:00
may as well pull the pan now and look at the rod brgs first. if they have damage then check the mains too.i am sure you have damage since you started it two times, and the brgs were dry from sitting.if it even ran 1 minute that is too long. I sure would not chance it to later throw a rod out the side of block. but of course it will be knocking first. did you have the exhaust pipe covered? as that's the biggest culprit.
