Re: 450 froze
old
04-02-2013 13:36:59
Once you get the water and old oil out your probably going to be ok. The pick up for the oil pump is very low in the pan so it was sucking on ice which of course will not move so yep no oil pressure. So you stand a good chance that it will be ok as long as the engine did not run long enough to spin a rod or main bearing out of it
