Super M steering gear question
Red Mist
05-04-2008 17:04:11
Howdy, boys: You know the half-round sector gear (19 tooth) which engages the worm gear in the steering box on top of the front bolster? Well, mine is badly worn and I wish to replace it with a newer, better (32 tooth) full circle gear which I have on hand - thanks to ebay.
My question is: How the dickens do I pull that gear? I can't see a way to get a puller on it, since there is so little clearance between the gear and the steering box. Somebody must have figured out a way to tackle this one. Please share you method(s) of success.
As always, thanks in advance to all participating on the forum.
mike
matt from wi
05-04-2008 17:22:17
 Re: Super M steering gear question in reply to Red Mist, 05-04-2008 17:04:11
Mike, when I rebuilt the bolster on my h I jacked the front wheels 1" off the ground. I then loosened the nut on the shaft holding the sector gear without removing it. Put a small 2X4 on top of the nut and hit it with a ballpeen hammer. I believe it is a tapered shaft and needed to be driven down. Its been a few years but that should work. Matt
Chris NW Ind
05-04-2008 18:11:48
 Re: Super M steering gear question in reply to matt from wi, 05-04-2008 17:22:17
Not tapered, splined. Mine was easy to pull. That may have had to do with fact that the nut was loose more than anything else--splines probably got a little wore. Remember, when you hammer the shaft you are also moving the thrust bearing and that will fight you as well.
I got a pair of channel locks on it and lifted. Easy as can be.
Chris B.
Nebraska Kirk
05-05-2008 07:02:00
 Re: Super M steering gear question in reply to Chris NW Ind, 05-04-2008 18:11:48
As a mater of fact, it is tapered AND splined :-)
Red Mist
05-04-2008 17:56:06
Matt: Makes perfect sense. What a foo-el I was not to have thought of that. Thanks.
mike
